5D8 circuit walk
  • 5D8 circuit walk
    I've been making a lot of noise lately trying to figure out the 5D8 so I'm trying to do a circuit walk and understand each part... not sure exactly WHAT I'm looking at though.
    Going to document this on a wiki later.
    A schematic is here:
    http://www.schematicheaven.com/fende..._5d8_schem.pdf
    From what I can tell, there's 2 input sections. The top one uses a bright bypass parallel its volume, so it's probably a bright input. Each input seems to house the preamp section.
    The top input on each seems to connect to a sort of negative feedback, anode to grid. I don't understand the arrows.. are those switches, such that the NFB is activated when using the lower connection, and disabled when using the upper? This would make sense to me, since the NFB gets inverted through one 12AY7 stage and hits the other grid in that case.
    The next stage seems to lead volume into a 12AY7 voltage gain stage, then into a 12AY7 current gain stage via cathode follower (warning: tube stress). The cathode follower should allow large amounts of current draw to supply the tone stack (lower current on high signal, rather than high current on high signal? My theory's fuzzy); 100k resistor seems to cool the tube (lest it overdrive like crazy) and allow this to be used as a signal path.
    The tone stack following is a psychotic crazy mess, what the hell? That 56k resistor next to ground looks like it could be the mid control if we throw a pot there instead.
    Following that, 12AX7 phase inverter. Is that an LTP? Uses a local NFB but I don't understand it. This whole section is a mess to me.
    That ground point isloates the PI from the bias circuit for the two 6L6 tubes. They output into a center tapped OT.
    The signal off the OT hits a global NFB circuit, returning inverted signal to the phase inverter to increase linearity and reduce overdrive. The 5K back there is a presence knob but effectively it acts like a bias adjustment for stage 1 of the PI.
    Power stage uses two 5Y3GT tubes to allow more current draw than one 5U4G. Uses a center tap standby switch to kill the B+ for the tubes. Full wave rectification, tubes heated by 5V localized AC that won't travel through the rest of the amp. Power stages have 32uF immediately available for B+ filtering, then 16uF for the screen grids, 16uF for the PI anodes, and 8uF for all of the preamp tubes and tone stack cathode follower; these capacitors are separated by resistors, it makes some kind of difference to performance.
    Because of the power supply layout, the preamp and tone stack cathode follower should sag first under load (they take less power, though, so I'm not sure; 8uF may be enough); the PI second; the power tube screens (distortion!); then the tube plates (more distortion!). I don't know how this plays out in real life, especially since the power tubes will demand more faster and probably really sag first, and cause the rest of the system to collapse with it.
    Music Tech Wiki!
    Looks like it uses a paraphrase PI (thanks CitizenCain for the link in another thread).
    Music Tech Wiki!
      The tone circuit looks sort of like a Baxandall circuit.
        Here, read up on tone stacks, in particular the Baxandal.
        http://www.duncanamps.com/technical/tonestack.html
        Check out the other tech info on that site.
        Stress? Cathode followers are no more stressful to the tube than the other gain stages. There is a power supply and ground, and there is a tube and a 100k resistor in series across them. it really doesn't matter much to the tube which order they are in.
        Did we not just discuss this exact phase inveter in anothe thread around here within the last 24 hours?
        Look closer, the 5k pot has a cap to its wiper, so the resistance in the DC circuit never changes, so it won't affect the tube bias.
        I am not sure how you came to this conclusion. All the stages except the power tubes are class A and their current draw is pretty steady. They won't be causing any sag. When a peak hits the power tubes, the plate supply - the first B+ node - will sag or drop. The rest of the B+ nodes are held up by their caps more or less. Until the plate node sinks below the screen node. At that point, the charge in the sceen cap would start to flow through the 10k resistor back into the plate cap. And so on.
        Due to the RC time constants of the filters, the lower voltage nodes will move up and down some, but not in unison with the plate node. They will remain comparatively stable.
        Once the B+ string gets as far as the screen node, it should be pretty smooth, and in my opinion, the rest of the node caps are more for decoupling than filtering per se.
        Why do you think the preamp would sag first?
          Am I right in assuming that you run musictechforum.com? In which case, I don't see why we should help you fill it with free content while you make money from your Google ads.
            I don't see why I should charge people to see a bunch of information I got from studying in classes or googling or pestering people on forums; free information should remain free.
            That being said, I also don't see what's wrong with the establishment of making money. I understand the concept of taking someone else's ideas or words and debasing their business model from it, preventing them from profiting (patents and copyright, respectively, are meant to control this); this happens whether you're making money off ads or not though. Wikipedia would be no more nor less a threat to Britannica if they put up google ads; nor would their users be any richer or poorer. They would, however, likely lose their 501(c)(3) not-for-profit status.
            Perhaps you would rather I simply ask questions, write everything in a book, build/sell amps, and let one person (me) benefit from the whole thing, financially or otherwise?
            (let's just ignore that it does cost money and time for Web hosting; I'm more interested in the philosophical end of the debate)
            Music Tech Wiki!
              Or you could simply invite people here where the discussion actially takes place.
                Yeah I didn't actually put up a forum did I...
                SEWatt, Epiphone's A&A forum, this place, there's enough.
                Music Tech Wiki!
                  If you have a forum, I don't know of it other than someone else's mention of it here. I cannot comment on your activities elsewhere.
