I´m switching between to gainpots with optocouplers. In the first picture you can se that i just placed two optocuplers to block backwards interaction.
In the second picture you can se how i did the switching in the Marshall SL-X.
I stole some current to the optos and put to mosfets to drive theme.
When the footswitch is opened the voltage to the first mosfet opens it and turns that opto on.
When the footswitch is closed the voltage to the first mosfet turns zero and the voltage to the other mosfet rises and opens that and that opto.
The problem is that when the switching that accurs when the footswitch opens make a realy loud pop, a realy loud.
The switching that occurs whene the footswitch closes is dead silent.
What is creating this pop and how can i stop it?
The switching at the same time switches two mastervolume witch the IC M5201 that is there original.
I did this switcihg before but with optos as masterswitches and that was dead silent.
Please help.
Please help.
