As many of you probably know by now with my incessant posting, i have a amp i built thats similar to a 50 watt jcm 800 2204. Main diff is the trannys and PSU. I can also use a pair of 6V6 with a bias change and setting the PT to 4 ohms with an 8 ohm speaker. When i first was deciding what to build with these trannys i decided on a 4x6V6 amp but changed my mind because i always loved EL34 marshalls and had many of them. Anyways, long story short, i again tried the 6V6's (jj's) after not having used them for a few weeks, and this time they sounded better than the EL34's. The tone is more focused and more springy. Just all around better, but the focus is what i realized the 34's are missing and the main thing i really like about the 6V6's.
Anyways, the question is what do you think the results would be if i went to my original design of a 4x6V6 output section? Do you think it would retain the same great tone? I'd leave it as is but it just doesn't quite have enough clean headroom. I'm pretty sure i know what i'll get as far as headroom, but i'm concerned that i might lose that sound. And i'm not talking about overdriven output tubes, but the sound i get at lower volumes where the outputs are still pretty clean. I just want that spound but a tad louder.
