Hi, I'm pretty new to amp building. I built a little Firefly last year and I'm itching to do another amp, but learn a bit more in the process. I have an EE background but not specifically in circuits and amplifiers.
I'm trying to come up with a BOM for a widepanel (5B6) Bassman but need a little help. Here's the (only) schematic and layout that I found:
Schematic: http://www.ampwares.com/ffg/schem/bassman_5b6_schem.gif
Layout: http://www.cnjradio.net/fenderamps/b...5b6_layout.gif
I understand the circuit from a high level (preamp, treble cut, phase inverter, power amp). My main question is on the transformers. I think a Hammond 125E will work for the OT (correct me if I'm wrong), but I'm really fuzzy on what kind of parameters the PT needs to have.
According to the layout, the output of the rectifier is 400 V. I did some back of the envelope simulations and think to rectify 120 VAC into 400 VDC you need a transformer with a ratio of 1:5.5 or so. I haven't been able to set up a SPICE sim yet to verify this. Assuming that is correct, where do I go from there?
Another minor question is that if the supply is really 400 VDC, 450 V caps is kind of cutting it close isn't it?
I've got all kinds of questions, but I won't drop them all at once.
