Hey guys,
I've got a question about the small-value capacitor that some guitar amp manufacturers put in between the push-pull out put stages at or around the phase inverter. Look at the phase inverter on this Sunn Model T schematic and you'll see what I mean. It's 270 pF in value here:
http://www.schematicheaven.com/newamps/sunn_model_t.pdf
AFAIK, the larger the value of that capacitor is, the more effective it is in rolling off high frequencies at that point in the signal path, and typically this is done to eliminate parasitic oscillations.
My question is, how can one calculate the roll-off frequency that exists because of that capacitor? It seems intuitive that greater capacitance will lead to greater high frequency roll-off, but at what rate? Does this equation apply to this situation?:
f = 1/(2*pi*R*C)
I've used this equation with success for figuring out frequency roll-offs when dealing with grid resistors, coupling capacitors, and output impedances, but I don't know how to apply it to the situation where a capacitor bridges tewo plate resistors in a phase inverter.
Thanks for any help/guidance you can provide. I know this is probably the nerdiest of nerdy questions dealing with amps.
Anson
f = 1/(2*pi*R*C)
Anson
