I apologize in advance for the noobie question, but I have looked everywhere and I cannot get my head around impedance.
I recently saw an analogy comparing a flashlight bulb powered by 4 AA batteries to a headlight bulb powered by a car battery. The flashlight bulb would represent a high impedance input and the smaller batteries a high impedance output. The car battery/bulb system is low impedance. If you mismatch the headlight bulb with the small batteries, it won't have enough power to light and the bulb will quickly drain the batteries. If you hook the small bulb to the car battery, it will light, but will not be using the car battery to it's fullest potential. I can understand this analogy, but when I read this paragraph last night:
A cathode follower is a means of coupling two sections of an amp together with minimal "insertion loss" or degradation. It has very low input capacitance and a very high input impedance so it will not load down the previous stage, and very low output impedance so very little signal is lost even when driving a very low input impedance. The cathode follower is an excellent buffer stage for driving a tone stack, effects loop, power valve or any circuit which would otherwise present a heavy load to a "normal" stage.
I am completely lost. If it has high input impedance, doesn't that mean it would severely IMPEDE the signal going into it? Can someone explain this impedance thing better to me in simple terms? Thanks in advance for any help!
