Hello and welcome to my first post!!
I have decided to design and build an amplifier. I am finding the design phase difficult because
A) I have no money and so I am using parts either "reclaimed" from other amps, or found in old boxes in the shed so I am having to shape the design around what I have available rather than designing it with the "right" parts
and
B) I have no knowledge of, or experience with electronics.
Still, building something that's directly wired to the mains supply, putting out 450 ish HT dc voltage and containing capacitors rated at 600v can't be all that tricky as an introductory project can it?
So to my voltage questions.
1) Looking at some old schematics shows the cathodes of the valves going to ground. Am I correct in assuming that this is not actually grounding to the chassis but is actually "grounded" to a low voltage supply approx 25v?
2) On the old schematics I have seen the tone controls are shown as providing a path to "ground". Is this actually grounded to chassis and not to the 25v supply?
3) Because I am using reclaimed parts my power transformer is ripped, sorry carefully removed, from a Marshall JTM 30.
It is for use in the UK and so accepts 240v ac. There are two tags offering 25v, two 6.3v, and two 325v. I am assuming that in each pair one is + voltage and the other - voltage. eg in the 325v pair one tag offers +325v with respect to ground (0v) and the other -325v. Am I correct in my assumptions?
I will be grateful for any help anyone can offer me!!
and
