I'm trying to come to grips with understanding something I've read about this on the Valve Wizard site. www.freewebs.com/valvewizard/index.html
Essentially, What is the "space charge" that supplies electrons to the grid when grid voltage approaches cathode voltage? I thought electrons flowed from the cathode usually, but I can't get my head around where they come from when the bias voltage on the grid is 0V (and you are still supplying a voltage swing into the grid), i.e. on the +ve half of swing when the quiescent grid voltage is 0V.
I want to understand, in intuitive terms, is howcome the current flows into the grid and down thru the cathode. If the grid is swinging positive (above 0V), surely it would be attracting electrons if anything. How come they are flowing away through the cathode?
