i'm trying to understand the way the node R values are selected and trying to figure out what i'm seeing in the 2205 and 4210 marshall schematics. I keep thinking i have to be spacing when i look at these amps because i don't see any PSU nodes for each preamp tube. in fact, it looks as tho after the PI the PSU has not nodes separating the 3 preamp tubes. (2 of the 5 are reverb and PI) What am i missing here? I was reprimanded over at ax84 once when i showed a schematic with 2 tubes on one node. yet unless i am spacing i'm seeing worse than that in these marshalls. The only thing i can think of is they are diode clipping amps and maybe they don't need much filtering because they are using SS overdrive instead of tube? Someone enlighten me please.
Second, can anyone explain to me a way to determine what resistor values to use at each node without electronic mathematics. Because someone already told me and i have to tell you math and the simplest equasions send my brain spinning. It's my absolute Achilles's heel as mental aptitude goes. i don't want perfect, just wanna see if i'm in the ballpark. If not, would anyone be able to if i post a schematic or post voltages etc?
