Motorboating. (sounds like an outboard motor on a boat)
Chokes in a Pii filter offer very good filtering. A choke steadys out changes in the current, helping to keep the voltage constant, whilst at the same time offering a low resistance to voltage. In the simplest terms I can come up with, this is to do with the interaction of the coil and the iron producing a magnetic field when a current goes through it, which helps buffer changes in current that result from rectification and capacitive filtering. It does this by offering a 'resevoir' of current (if you like) in the EM field surrounding that part of the power supply wire.
Chapter 3 on this page is a good tutorial site for valve amp power supplies.
http://www.tpub.com/content/neets/14178/index.htm
