I am building a Marshall JTM45/Bluesbreaker clone.
I have read that the Blusebreaker tremolo does not sound that good. I would like to build the amp with a better tremolo that I can put in place of the original tremolo, which is on a separate board from the main JTM45 board. The Bluesbreaker chassis has the one preamp tube for use with the tremolo and I do not want to add any more tubes, etc. I also want to be able to switch the tremolo completely out of the circuit when I want to and get the full gain of the JTM45 circuit. Finally, I don't want to use any parts that are impossible to get.
What are some of the better sounding tremolo circuits that would work? I have been thinking about the following circuits from surfing around on the net, but I don't know a lot about design, etc. to know if they would work without a ton of tweaking, etc. or if there are better circuits:
Fender brownface 6G16 tremolo
Marshall 18 Watt tremolo
Vox AC15 tremolo
Matchless Hurricane tremolo
There may be others that would work or sound better. Thanks for any tips or advice.
Vox AC15 tremolo
