I have this fundamental mis-intuition about the nature of class AB operation that I know is wrong, and I've had it as long as I've known what class AB is. I assumed one day I would know enough to get it. That day never came...or it came and I've already forgotten (happens way too much)
This question applies to all class AB amps but it is a little easier for me to picture if I imagine a very hot biased amp. With low enough input signals, neither tube will reach cutoff during a cycle and the amp is operating effectively at class A. Increase the input and each tube is cut off for some portion of the cycle. Intuitively, I feel like the output should drop for this portion of the waveform, and you'd have some sort of class-breakover distortion. Why doesn't this happen? Where does the energy come from to keep the signal going during those portions of the waveform when only one tube is doing the work, same as it was when there were two?
I can accept this much easier in solid state amps, where open loop gain is a bazillion and tons of feedback can force the working transistors to keep up. But that can't be the reason since tube PAs don't have nearly as much gain or feedback, and in some cases, no feedback. What am I missing?
