I never quite got the signal flow through negative feedback. For the simplest example (I think) take a champ. Read through some vacuum tube books, and managed to understand why signal is inverted at the plate relative to the input grid. And signal is in phase between input and output of the output transformer.
If that's the case, then a positive half cycle at the input flips to negative after the first half of the preamp tube. The signal at the cathode of the second half of the preamp tube is in phase with the grid so its also negative half cycle. at the plate of the second half of the preamp tube, the signal is positive again. Then flips one more time going through the output tube.
Why would the speaker signal be a negative feedback if tied to the cathode of the second half of the preamp?
