@Teemuk: Yes. there is a similar ongoing discussion in the high-accuracy amplifier hifi world about soft clipping, where the problem is steering between the harsh clipping of 0.0001db over the power supply limit of the amplifier, and the limits of accuracy if you don't use soft clipping. The camps are (or were, when I last read about that) loudly divided over whether it's better to have soft clipping to hide the hard clipping when you run out of amplitude, or just build monster amplifiers that never -ever- get over the amp's clipping limit. So you have a fractional-kW amp to put out 1-2W of actual music and not clip. Scylla and Charybdis here.
@loudthud: There are several ways this is dealt with. Some of them have zero signal be active 50% duty cycle, constantly. So they never collapse in the sense I think you mean.
