To me a "pilot light" is a small flame (like on a gas water heater) that helps with ignition. I refer to the "On/Off" light as an "Indicator Light".
Why is it called a "pilot light"?
I convinced myself that PL originally was an abbreviation for "panel lamp", from way back in the golden days of relays and cam sequencers. I catch myself calling them pilots lights more often than not, although I guess the word 'pilot' can have the definition of an indicator function?If it still won't get loud enough, it's probably broken. - Steve Conner
Why is the flame on a water heater called a pilot light? It doesn't fly, or act as a guide. Things are given names that make no sense.
Fun fact: the term "sky pilot" predates human flight and was used for preachers or missionaries because they would guide you to heaven, or something.
Originally posted by glebert View PostWhy is the flame on a water heater called a pilot light? It doesn't fly, or act as a guide. Things are given names that make no sense.
pilot lamp
noun
an electric lamp, used in association with a control, which by means of position or color indicates the functioning of the control; an indicator light or a control light.If it ain't broke I'll fix it until it is...
- 1 like
I have been electronicing for 65 years or so, and it has always been "pilot light" to me.
I am as guilty as anyone of calling lamps "bulbs." But what we call a bulb is a "lamp". The fixture with a bulb in it is a light. On the panel of an amplifier, the pilot lamp is inside the pilot light.
"Bulb"? That is the glass part of a lamp.Education is what you're left with after you have forgotten what you have learned.
- 2 likes
Here it´s "lámpara piloto", literally "pilot lamp" since forever.
An "indicator" is a needle pointing at something significative, say a clock hand, or a ship relay panel.
Which is not a coil pulling contacts by any means but:
- 1 like
Originally posted by galaxiex View Postpilot lamp
noun
an electric lamp, used in association with a control, which by means of position or color indicates the functioning of the control; an indicator light or a control light.Experience is something you get, just after you really needed it.
And of course we all know that a "relay" is not a coil and contacts, but as a verb - the act of getting something somewhere else - and as a noun - the thing that gets something somewhere else - like a relay race.
Which fits the shipboard context perfectly:
captain "ahead full"
helm "ahead full, aye" - pulls the relay control to ahead full
the relay in the engine room indicates ahead full, the bell dings.
the engineer shouts "ahead full!" (engine room very noisy)
the boiler tech/engineman/reactor operator shouts back "ahead full, aye" - pulls lever/turns knob/moves slider
the equipment responds.
and then the message returns via the same relays from the engine room to the captain "all ahead full"
relay races for everybody!!Last edited by eschertron; 10-17-2020, 10:52 PM.If it still won't get loud enough, it's probably broken. - Steve Conner
- 1 like
