Hey folks, this came in with sound cutting in/out. All the pots were super dirty. Gave it a good cleaning amp sounds great all the pots work. Went to reassemble it into the head cabinet, with 2 chassis bolts, to test the reverb since it's mounted in the cabinet. There is a hum, which I believe is 120 cycle. I was moving reverb cables around and also tapping on the chassis, the hum would come and go. I thought okay maybe bad reverb cable something loose in the amp. Took it out of the cabinet to poke around with my sharpie. Nothing responded to pushing around or tapping... nothing. This amp has a star ground that is lifted off of Earth by a 22ohm resistor with 2 diodes and a cap in parallel. The star ground measures 22ohms to chassis with my meter.
Here are some tests I tried, and while they haven't pointed me in the right direction maybe they'll point you guys toward a clue...
The hum is there with ALL knobs at 0 except for the Master Volume, yes even the reverb at 0 (on BOTH channels)
If I touch the red reverb return plug shield/ground to the chassis, the hum goes away (this doesn't happen to star ground)
If I turn the Presence up to 12 the hum goes away
If I pull V2 the hum goes away
If I short V2A grid to the chassis the hum goes away, (doesn't happen when use star ground)
The hum goes away if I connect star ground to Earth
I've tried new preamp tubes, didn't help
The low voltage bipolar supplies are good
Whatcha think? I'm stumped... I even put the chassis back into the cabinet thinking maybe the cabinet shielding plate played a part. I couldn't make the hum go away anymore after tapping around on the chassis with it mounted tightly in the cab.
Here's the schematic - https://www.thetubestore.com/lib/the...-Schematic.pdf
