Hello. Built this 12bh7 driver. I.m not pretty sure I understood correctly how it work. Should I follow 542+88V as supply voltage to describe the load line ? I ask for a basic theory how this driver in common mode work please. The voltages are directly picked from my test circuit.Input signals are supposed to be perfect balanced.The voltage amplification is 15 from my measurements. Thanks.
Common mode theory for newbie
Last edited by catalin gramada; 01-04-2021, 02:24 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
There was two reasons from my point (noise reduction not included) : First : to keep output signal balanced (a semipot will be included in the plate circuit if necessary for adjustment), second : to benefit by full amplification (with individual unbypassed cathode resistors the voltage amplification is half by that 7,5)"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostThere was two reasons from my point (noise reduction not included) : First : to keep output signal balanced (a semipot will be included in the plate circuit if necessary for adjustment), second : to benefit by full amplification (with individual unbypassed cathode resistors the voltage amplification is half by that 7,5)
After all it's a differential amplifier with very low common mode gain.- Own Opinions Only -
No it is not a phase inverter. The phase inverter I used is a dc coupled cathodyne as preceding stage. The signals at the inputs of this driver are inverted and supposed perfect balanced.
In common mode the gain is almost as much as the tube can provide : 12BH7 u=16. I get litle bit over 15 in my circuit.Last edited by catalin gramada; 01-04-2021, 03:15 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostNo it is not a phase inverter. The phase inverter I used is a dc coupled cathodyne as preceding stage. The signals at the inputs of this driver are inverted and supposed perfect balanced.
That would mean differential - not common mode operation, the input signal between both grids being Vin= (V+) - (V-)=2V+.- Own Opinions Only -
- Likes 1
It works as a differential amplifier (amplifying the difference between the grid signals) to each of the out-of-phase outputs. No difference to an LTPI.
Even feeding only one grid would produce output at both plates - but only half as much.
For (undesirable) common mode, both grid signals would need to be the same (not out-of-phase).- Own Opinions Only -
- Likes 1
