Anyone who is studying up on tube amp construction (or even soldering) will hear the same phrases over and over: “the parts being soldered must make a solid mechanical connection,” and “solder is not glue!”
I took this advice to heart and made sure every wire was wrapped around every lug. Doing so took me longer to build anything and even longer to repair or mod. And more often than not I’d find a securely wrapped wire than hadn’t been soldered, but was causing issue under vibration. It was a problem I’d read about happening to others (and still come across all the time on forums).
The more pro amps I saw (vintage and new alike) inside of the more realized no one was following the rules stated above so religiously. Surprisingly none of their amps were falling apart with wire flying out of their places. I took a leap of faith, started simply sticking wires through pot and tube lugs, and just soldering them in place. When I learned about pcbs it became even clearer that this was acceptable practice (a flying lead can’t be wrapped around a solder pad!).
So I’m curious to hear other opinion about this subject and my rant. But I’m here to say that building and modding my own amps has never been more fun since I stopped obsessing about wrapping every wire, and now it’s much harder to miss a connection.
