Hello guys,
i've been desining a low watt amp as a PP of ecc99. It has a cathodyne PI and the NFB signal is injected in the stage before the cathodyne. The amp is working good, except that the presence and depth pots don't do nothing (almost). The values i took are for a marshall.soldano PI (long tail). I wonder why it does not work as well as in those amps. First the signal from the 16 ohms tap is quite weak, i had to reduce the nfb resistor to 1K5. If i put 4.7k i have almost no feedback. The depth pot is effective only in the 20 first percent and acts more as a loudness control, not only the low end is pushed. And the presence pot does nothing at all.
Which values of pots and capacitor, or circuitry to get effective resonance controls?
I post the preamp and power stage, the PSU is very common...
Thanks for the help you can bring me...
