The title says it all. Typically we select wire based on its current rating? In the context of heaters, grids, anodes etc is wire gauge worth considering in the context of noise of any kind? Would it be a bad Idea to use 16 guage wire for everything say?
Is em or thermal noise a consideration when selecting wire gauge
No, it's certainly not with tube amps.
It's all about wiring resistance (regarding thermal noise and voltage drop). Tube amps are high impedance, low current circuits, so the influence of wiring resistance is totally insignificant. Exception is the heater wiring regarding voltage drop - not noise.
Another exception would be a ground bus, where tiny voltage drops could be amplified by input stages.Last edited by Helmholtz; 02-27-2021, 06:01 PM.- Own Opinions Only -
- Likes 2
16AWG must be unwieldy wire. For example to place two wires in the same noval socket pin, potentiometers ... (in mini switches, better forget it). Except for some filaments strings I see it unnecessarily thick.
0.5mm^2 (20AWG) I consider it a much more suitable gauge for general applications.
- Likes 1
Originally posted by Pedro Vecino View Post16AWG must be unwieldy wire. For example to place two wires in the same noval socket pin, potentiometers ... (in mini switches, better forget it). Except for some filaments strings I see it unnecessarily thick.
0.5mm^2 (20AWG) I consider it a much more suitable gauge for general applications.This isn't the future I signed up for.
Thanks. To be honest my immediate requirement is that upon taking a look inside my recently purchased fender custom 68 deluxe reverb, the heater wiring is very loose and sloppy in places. I'm looking at small incremental steps towards reducing noise in this amp as a learning exercise. I know there are known issues with this amp, some of which I have already addressed, but I thought re doing the heater wiring with a tighter twist etc and replacing the virtual centre tap with a bias pot might be a worthwhile project for an afternoon, but I was unsure which wire I should purchase to have on hand if the existing wire is not long enough. Off the top of my head the combined heater current approaches 4 Amps based on datasheets.
Originally posted by Urumiko View PostI'm looking at small incremental steps towards reducing noise in this amp as a learning exercise. I know there are known issues with this amp, some of which I have already addressed, but I thought re doing the heater wiring with a tighter twist etc and replacing the virtual centre tap with a bias pot might be a worthwhile project for an afternoon, but I was unsure which wire I should purchase to have on hand if the existing wire is not long enough. Off the top of my head the combined heater current approaches 4 Amps based on datasheets.
Radiated heater noise is 50Hz hum.
