Originally posted by g1
View Post
KT88 amp
Doesn't seem to make sense.
Something is missing. Maybe oscillation involved?
Can you post scope pictures of grid and output signals? And don't forget the scope settings.
1. Output max clean signal. 1V/div, 10:1 probe. 1kHz
2. Output max signal clipping about 75W, same settings.
3. Grid max clean signal, same settings.
4. Grid max signal clipping, 2V/div
I see no signs of oscillation, my scope goes up to 100mHz.
What's interesting to me is how the signal compresses, but I'm able to feather it back up... go slow enough and I can almost hit 60W clean, but this isn't the kind of dynamic I want in a bass amp
Originally posted by g1 View PostHave you tried altering your load resistance?
And that GEC datasheet seems overly optimistic to me. Plugging your numbers into Nick's calculator gives around 60W with your values and 70V p-p signal applied.
Not 70W, but more than 50 anyway. I had it set for -46V bias and didn't re-try with the lower bias number (-41V).
- Likes 1
Originally posted by hylaphone View Post
I've not tried changing load resistance. I could halve it using a different tap/same load but 2.5K seems like an awfully high load for this amp?
But just to be sure, the tap arrangement on this model OT is not so simple. Are you using one of the wiring schematics from the attached datasheet?Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I'm not clear on the amplitude of those grid waveforms. 60Vp-p unclipped, 120Vp-p clipped?
Something odd there.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yes, halving it would be too much I think.
But just to be sure, the tap arrangement on this model OT is not so simple. Are you using one of the wiring schematics from the attached datasheet?Last edited by hylaphone; 06-12-2021, 07:48 PM.
- Likes 1
Here are some.
4. Assuming AC coupling, the positive going grid signal gets clipped above 20V. Looks like grid conduction but way too early.
Do both KT88 grid signals look the same?
Do you have another set of KT88s to try?
If not you may temporarily try a set of 6L6s- Own Opinions Only -
- Likes 1
1. Means 52Vpp or 42W into an 8R load.
Same settings, top trace is the grid of the "top" KT88 on the schem, driven by the non inverting half of the PI. 220K grid leaks are still in place.
Sorry for the blurriness, it's hard to photograph a trace!Last edited by hylaphone; 06-12-2021, 09:40 PM.
Here is a shot of both grids with a different pair of KT88. Second trace inverted for comparison.
Did you use same scope settings?
Can you confirm that different KT88s cause different grid signals?
Do you see the PI output imbalance and triangular waveshape also with KT88s out?Last edited by Helmholtz; 06-12-2021, 10:58 PM.- Own Opinions Only -
Not nice, because signals are not balanced and look triangular instead of sinusoidal - but no top side clipping above 20V like in your picture #4 above.
The different sets of KT88 show identical behavior.
Here are pics with the KT88 removed. First pic is max clean signal, 2V/div, 10:1 probe. This shows 130Vpp from the top half of the PI, and 150Vpp from the bottom, inverting half.
Second pic is full clipping with KT88 removed. Both sides around 160Vpp.Last edited by hylaphone; 06-13-2021, 04:08 PM.
With the KT88s installed, more careful measurements show it's worse than I thought.
520V on the anodes, 360V on the screens, -41V on the grids. 220K grid resistors.
First pic is the the grids at max clean signal. 1V/div, 10:1 probes. Top trace is the non inverting side, 35Vpp. Bottom trace is the inverting side, 45Vpp. This produces 35W output.
Second pic is full clip, 2V/div. Non inverting side 120Vpp, inverting side 90Vpp.
This makes around 70W output.
What do these waveforms suggest?
First make sure that both scope channel knobs are in arrested CAL positon.
Ok, now adjust the PI input signal to get around 100Vpp at both PI outputs. (Does balance improve?)
Then lift one end of the NFB resistor and reinsert power tubes. What happens to the grid signals?
