I'm hoping to recreate the tone stack out of an SWR working man's 15 amp because I liked the flexibility of it when i had one a few years ago. The amp was just too heavy to carry around for rehearsals, so i moved on. I'm now considering using the SWR circuit as the basis for a preamp pedal, and I also just want to learn.
The mids portion of the tone stack is shown here: https://imgur.com/a/KcjzPBt
I used circuitlab to model the entire tone stack, and the frequency response shows the mid peak moving from about 750Hz to 1kHz with the frequency knob.
The label on the original amp indicates a sweep from 200 to 800Hz.
It's a big difference that I can't explain. Undocumented component changes? Interaction with other parts of the circuit? Fudging of values on the panel?
Any thoughts?
Any thoughts?
