So, I'm working on an old Knox amp. Tube compliment is 2x 12ax7, 2x 6bq5, and a 6ca4 recto.
Looking at the guts, I noticed that the first filter cap is 80uf, which is way bigger than I'm used to seeing. All the datasheets I've seen list the max input filter as 50uf.
I am re-capping the thing, should I go back down to something like 47uf? It seems odd that stock they would use such a high value, but the little bit that I heard from playing it, sounded nice.
as is, the power supply layout is:
recto--->80uf input filter which feeds the OT center tap--->2k2---->80uf which feed the screens and all the preamp tubes.
B+ is pretty low in this amp: 280v at the first filter node.
