SMD IC orientation
  • SMD IC orientation
    How do we find pin 1 on a SMD chip with no dot or end notch? Can we assume pin 1 is at the lower left with respect to designation printing?
ID:	937960 Click image for larger version
    Can you see a slightly beveled edge on one side of the package? That's the pin 1-4 side.
    It looks like the bottom edge on your pictures so pin 1 would be bottom left.
        Who needs glasses when you see things we donīt?
Name:	IC pin1 chart.png
            Is this industry standard or just NTE?
            Thanks,
            nosaj
              It''s the standard. Pin 1 is the lower left corner when facing correctly what's printed on the IC.
