I was just purusing a radio ameture's site <http://www.radioremembered.org/outimp.htm> about measuring the turns ratio, sqaring that and coming up with an impedance ratio. He came up with good numbers, but when I measured my '68 Bandmaster OT, my calculations came up with less than a K for the primary between the red and brown lead.
Here's my numbers: measured at 120 HZ
Red to Blue primary: 7.350HY
Red to Brn primary: 7.185HY
Blk to Grn secondary 48mhy
The impedance ratio is 7.185/.048? That would be about 150. Then the turns ratio = sq. rt. of 150, or 12.
When I hooked up my sig. generator to the Red/Brn leads I came up with 534mv. into the primary, and 34.2mv. at the Blk/Grn leads, indicating a turns ratio of 534/34.2, or 15.6.
So, lets just say 15. 15X15 = 225 (turns ratio squared = impedance ratio)
With that ratio, the reflected impedance to the primary from a 4 ohm load would be 225 X 4, or 900 ohms.
Where are my thousands of ohms of impedance at?
