Hi chaps, another basic amp question from me Im afraid.
What is, or what would be the difference between an amp head -with two output ports, 8, & 16 ohms- going into an 8 ohm speaker ( using the 8 ohm port), vs a 16 ohm speaker ( going into the 16 ohm port) ? And if its a 35 watt amp, does that make any difference/ is that relevant?
I mean amp characterists. What would I, as a player, hear. The exact same? Half the volume? Twice the volume? Any difference(s) at all ?
Apart from dividing two 16 ohm speakers, to make an 8 ohm load ( if an amp only has on 8 ohm port that is ), by putting them in series ( iirc, or parralel).. I just don't undertsand this different ohms thing with speakers. (Why aren't they all the same? Or rather i mean why shouldn't they be all the same?)
I mean why an amp would even have two different ports, like my eg, if you can " make" whatever the amp should have if it has just a sole one, by putting two speakers in series or paralleling two.. I cant understand either.
Thanks. SC
Thanks. SC
