I built 2 amps that are almost exact (same trannys, choke, signal caps, etc) except the layout and the PI and preamp filters. Tho the 32/32uf can is the same in both. I gave the first to a friend and i have the second. Mine sounds amazing and very very marshally with pristine highs and lots of complexity. It's a very lively amp. the other is much darker and lifeless by comparison and doesn't sound like a marshall. I've tried playing around with his and changing the layout to reflect mine. i've checked voltages and tried to make them match closer. Checked component values, etc. The only thing i haven't done if to replace the sprague filers with F&T's as i have in mine. It's pretty much the only difference in components.
I always read about filter caps no making any notable tone difference, but i can't help but wonder. They ARE different values, but i don't think 20uf verses 22uf would make any notable difference. Could the difference in brands make that kind of difference?
