Originally posted by g1
View Post
mystery power transfomer - measuring voltages across all secondaries
Originally posted by boroman View Post
I'm 100% sure one side are primary and the other secondary (just before my 110/120/220/240 power switch broke it was wired to "tube socket-like" switch)
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Here's what I would do:
1) Isolate all wires and tape them to a piece of cardboard, wood etc.
2) Connect the heater voltage from another transformer via a 22R/5W series resistor to the brown wires.
3) Measure the voltage across the brown wires, if around 7V....
4) Measure all winding voltages
5) Once you've found the correct primary configuration, connect to your mains via a (60W) bulb limiter and measure all winding voltages.
Unloaded secondary voltages might be high by ~10%.
Do you remember anything about the mains selector switch wiring?Last edited by Helmholtz; 02-21-2022, 07:24 PM.- Own Opinions Only -
- Likes 4
So other working/known transfomer with heater voltage, and its each 6,3V wire connected with 22R/5W to each brown wire of the unknown transformer?
1st wire working OT 6,3v ----> 22R ----> u/o PT brown wire 1
2nd wire working OT 6.3v ----> 22R ----> u/o PT brown wire 2
Like that?
Why I need to put resistors there?
Originally posted by boroman View PostSo, If I understand correctly, I am connecting it other way round to get "right" voltage reading at primary side, e.g. in my case 240V?
Is 240V your nominal mains voltage?
Like that?
Its purpose is to protect the "donor" transformer from potential shorts.- Own Opinions Only -
- Likes 2
I'd think 1 resistor in the circuit would be sufficient. That is used for current limiting to protect life and property if something goes amiss during the test.
6.3v / 22R (short circuit on the test side) = under 300ma load on the supply transformer. That's protection for the 6.3v winding on the supply.
Also current limits the unit under test, if you short (or grab) two wires with a potential across them.
edit: simulpostIf it still won't get loud enough, it's probably broken. - Steve Conner
- Likes 3
Yes, 240 is my main wall voltage.
So, Only one 22R resistor no matter on which one wire. Allright. I could use also fuses there, right?
So, I'd need to find two wires on the primary side that have approx 120V and join them together to have 240 primary? (+/- 10% of course, no load)
Did you apply the 6.3V from your source thru a 5 watt resistor to one of the thick brown leads, and the other thick brown lead went back to the other end of the 6.3V source? Just verifying where you applied the voltage.
Was your 0.2VAC measured across the two thick brown leads of the test transformer? If so, that would indicate that the thick brown wires are shorted.
If the resistor and the solder connections are good (soldering doesn't look great), you have a short somewhere and the resistor should get hot.
Could be some PT wires touching or an internal winding short.
In any case the heater winding (as well as all other PT windings) will look like a short.
I see you used an ancient 40R/5% resistor probably rated for no more than 2W. The test sholuld work nonetheless.
