I'm ordering some more screen resistors for a EL34 JMP type of amp. Last time I chose a 2k for each EL34 for safety but now considering splitting things.
A 1.5K 10 watt "choke" resistor Y'ing out to 100Ω or 270Ω on each grid? If a tube goes down there may be less heat through a lower value here with the other perhaps helping out?
From watching these ToneTalks with Friedman here also espouses less filtering say, 80uF to allow the ghost notes. So short of adding a switch for these big components to gear things up, I'm wondering the best approach?
I might, down the line, like to use my KT77s or 88s. I also have an old pair of 6CA7s. Metro. amps said he prefers higher 2K to protect against iffy tubes. Also, I'm about to install 1Ω resistors on the cathodes for biasing ease.
The screen resistors are a too common failure point and I've replaced a few even with 6L6 tubes.
I don't have a choke on this '72 Traynor and am shy to add one as it might radiate hum. It's pretty quiet now.
Thank you
Thank you
