Mains voltage in the UK is 230V. Many of the old valve stuff here was sold as 110V with heavy step down transformers. like this filmosound projector
Say if I have 2 identical 110V power transformers, could I wire the primaries in series and the outputs in parallel to make a power supply that works for UK/EU mains power? I don't know what the measured wall voltage is in the US but seeing as my wall measures 234V I would imagine the US mains is a wee bit higher than the 110V nominal. I therefore don't see 2 x 110 as being very different from 230V in practical terms.
I'm thinking something like if you have 2 x 110V monoblocs and you wanted to use them as a 2 channel stereo amp, could you wire up the transformers as described to make a single power supply for the 2 of them or just use the 2mains transformers to make a very stout PT for a mono amp
thanks,
thanks,
