I have seen this on a few amplifiers. Why do they put a small value capacitor across the large value filter capacitors?
Small value cap across large filter caps?
The huge caps smoth ripple - low frequency noise. But they respond poorly to high frequency noise. The small caps however respond well to that, shunting noise off the rails.Education is what you're left with after you have forgotten what you have learned.
For low distortion (and sometimes stability) at high output currents it is essential that filter caps have very low impedance at all audio frequencies.
Older ecaps often had increased impedance (composed of ESR and inductance) at HF.
Paralleling foil caps lowers HF impedance.
Modern ecaps suitable for SMPS application have very low impedance even at HF, so adding foil caps gives no benefit.- Own Opinions Only -
- Likes 1
Originally posted by Axtman View Post
There is a article with some decent math by Jim Hagerman on calculating their values, available by googling "calculating optimum snubbers hagerman"
- Likes 1
Originally posted by Enzo View PostWhy is there air?If it still won't get loud enough, it's probably broken. - Steve Conner
