I am thinking of getting a tremolux 5G9 made for me and I just had a question, would the 5G9 benefit from a negative feedback loop? How is the clean headroom on the stock 5G9 which has no NFB loop? I don't really like the tweed deluxe which has no NFB loop but I like the other tweed amps like the 5F2a princeton that do have the NFB loop just because they will stay cleaner a little higher up the dial. I really like the tweed bassman which also has a NFB loop, I like how the bassman can go up to about 4.5 on the dial and remain relatively clean. Would the tremolux need a NFB loop in order to remain clean on up the dial like that bassman or is the tremolux pretty clean already even without a NFB loop? Is there any issues with the circuit in adding a NFB loop? Thanks
Tremolux 5G9 w/ NFB loop
Just thinking out loud: Since it's a build, why not make NFB switchable? It shouldn't cost much- a couple resistors and a switch. Or, add a pot and make it variable. This way, you could play with options and see what you like best."Yeah, well, you know, that's just, like, your opinion, man."
- 3 likes
Originally posted by KenyonMI View PostI … I don't really like the tweed deluxe …
Plus the 5E3 output valves are cathode biased, idling at high anode current, so the stage gain will be high, whereas the 5G9 is fixed bias, so can be idled cooler, and so have a lower stage gain.
- 1 like
An NFB loop will try to kill the Tremolo. Can anyone find a bias wiggle tremolo with NFB ?WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostAn NFB loop will try to kill the Tremolo. Can anyone find a bias wiggle tremolo with NFB ?
But I tried it with a build and I'm not convinced it's a good idea. The trem is "okay" but could be better. I'm probably going to change it."Take two placebos, works twice as well." Enzo
"Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
If the bias is too hot, the trem effect depth is reported to be poor.My band:- http://www.youtube.com/user/RedwingBand
- 1 like
I never thought about the NFB loop affecting the tremolo but that does make sense. If I did do it I would definitely make a switch to go on and off. I have been trying to read up on it and seems people say the 5G9 tremolux stays pretty clean almost half way up the dial and so it may not even need a NFB loop. What sparked my curiosity about a NFB loop in a 5G9 was in reference to a 5F11 which has a similar trem, similar wattage, and it does have a NFB loop. If anyone has any experience, does the stock 5G9 have at least as much clean headroom as a 5F11?
Originally posted by guitman321 View PostI have 6g11 and 6g16 and the tremolo is fine. I do run cold bias, around 50%."Take two placebos, works twice as well." Enzo
- 1 like
In the context of guitar amps clean headroom typically means available clean output (numbers on pot dials don't have a meaning by themselves).
NFB doesn't increase output power and will not noticably increase clean headroom.
Also NFB only affects the power section, most notably showing in less power stage gain. Means that you need more preamp signal/gain for the same output.
This in turns may cause increased preamp distortion depending on the circuit.
NFB does change the sound and "feel" of an amp, though.Last edited by Helmholtz; 04-13-2022, 01:03 AM.- Own Opinions Only -
- 3 likes
Originally posted by KenyonMI View Post… What sparked my curiosity about a NFB loop in a 5G9 was in reference to a 5F11 which has a similar trem, similar wattage, and it does have a NFB loop. If anyone has any experience, does the stock 5G9 have at least as much clean headroom as a 5F11?
Keep in mind, especially in that era - the amps are not consistent. All 5G9 amps didn't sound alike. They used low tolerance parts and tubes were luck of the draw.. It is really difficult to compare models based upon ONE factor and expect consistent meaningful results.Education is what you're left with after you have forgotten what you have learned.
Even 2 identical amps may appear to have different "headroom" as one of them starts distorting with volume at 3 and the other with volume at 5.
Simple explanation: Vol pots having different tapers.
Bottom line: Headroom only makes sense when related to a power measurement.- Own Opinions Only -
- 1 like
