Switch power supplies?
  • Switch power supplies?
    I see Blackstar has a "lightweight" new line out with "no conventional power transformer." It certainly has a very small PT buried in a switch mode power supply (SMPS). I've often thought they'd be a good idea for a tube amp, since the 80s when I first encountered them - potentially halving the iron weight.
    Has anyone experimented with higher current switchers? I've built preamps with low current/high voltage SMPS, but nothing that could supply dozens of watts to power tubes.
    <snark>Hopefully Blackstar hasn't patented using a SMPS in a tube amp like they patented their variable slope resistor</snark>
    There’s the Crate V33 https://el34world.com/charts/Schemat...te_v33_212.pdf
      Nothing inventive with a high voltage high power SMPS.
        Originally posted by pdf64 View Post
        Thanks. (Crate, the paragon of quality. )
        Everything in there looks fairly standard from a SMPS point of view - the trick is getting or winding the transformer!
          Just about any desktop computer has a SMPS in the 50W to 300W range. If you can find a dead one, they can, with all due caution, be repaired. The trick to re-winding one is to figure out which winding is used for feedback.
            I don't understand why mainstream tube amps didn't go over to SMPS a long time ago, given their efficiency, broad input voltage tolerance, and low manufacturing cost - though from a repair perspective they are more involved to troubleshoot. I suppose one aspect is that they're very well regulated and maybe too 'stiff'. You'd think that this could easily be designed out to give load-dependant sag.
              Yes to both, but Musicians, in theory "revolutionaries" and "free thinkers" in practice are the staunchest Conservatives on Earth.
              At least as far as guitars and amps are concerned.
                Walking oxymorons or contradictions.....
                nosaj
                  It'd be easy enough to add an RC at the output to add some softness.
                    SMPS is a great idea...as long as they're MODULAR! Meaning, easy to replace as a unit. They're cheap!
                    http://amps.monkeymatic.com
                      Soldano has released a 30W amp with an external SMPS and a class D power amp. Sorry, no tubes.
                      Read about it here: https://www.ssguitar.com/index.php?topic=5155.0
                      casibom betturkey
