Hello. How can inject some global nfb into ltp please ? The circuit is excellent balanced using -100v negative into the tail. The problem is injected even some small nfb amounts like 6 db or so into the grid of non inverted section over 10 ohm shunt makes the outputs severe unbalanced. May you suggest another solution please ? Thx.
LTP NFB question
LTP NFB question
Last edited by catalin gramada; 10-30-2022, 03:17 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
Are you sure that the feedback was negative, rather than positive?
How about adding grid stoppers, eg 10k or 22k on each?My band:- http://www.youtube.com/user/RedwingBand
Try this
Grid loads are of equal value (I used 330k)
- Likes 1
But with your proposal the NFB signal would be applied equally to both grids, so both NFB and PFB. Means no feedback in effect.
The left grid leak should go to ground instead.Last edited by Helmholtz; 10-30-2022, 04:40 PM.- Own Opinions Only -
- Likes 1
Originally posted by Helmholtz View PostDoes the plate DCV change when you connect the 220R FB resistor?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I like the idea of equal grid loads.
The left grid leak should go to ground instead."Take two placebos, works twice as well." Enzo
- Likes 1
What happens to symmetry if you insert a grid stopper at the right side of the same value as the left side grid leak (e.g.1M).
I know this will change/increase HF response, but it's meant to test if the problem is caused by grid load asymmetry.- Own Opinions Only -
Yes. This works well also. There was a tiny shift in phase but I didn't check it for an absolute figure. The output for both redraw circuits is identical.
Originally posted by catalin gramada View Post
Both of my redrawn circuits work. Helmholtz has more technical prowess by a stretch so if he thinks the input grid leak should be grounded, do it that way. So, the second redraw. ta2"Take two placebos, works twice as well." Enzo
