Tube retainer clips problematic?
Mick,
Good idea about the silicone tubing. I will not name names, but the guy I heard it from runs a popluar amp repair YouTube Channel. I agree with everything else he says about amp repair. This comment made me pause. He explains the difference between the metal and glass cause thermal stress in the glass.
He did not say this but I wonder if the grounded spring clip affects the amp electrically?
I usually use "bear trap" style tube retainers. The amp I am repairing has 6550 tubes and the tubes point up from the chasis, not hand down like Fender amps. I thought I would install these retainers just to be sure the tubes don't get jossled out of place or loose from transport.
I think nevetslab could add some own experience with those retainers.
Measuring bulb temperature requires using a thermocouple and a little heat grease for heat transfer.
An infrared thermometer is likely to give wrong results as the glass doesn't reflect like a black body. In fact it's rather transparent to heat radiation.
So one would have to paint a black spot on the bulb and focus on it.Last edited by Helmholtz; 03-16-2023, 12:16 AM.- Own Opinions Only -
Originally posted by Helmholtz View PostI think https://music-electronics-forum.com/...5293-nevetslab could add some own experience with those retainers.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Mick Bailey View PostThe only problem I've encountered with this type is spring rattle, cured with high-temperature silicone tubing. I've never done any checks, but the metal retainer cap always seems to run cooler than a naked glass envelope. I think the metal dissipates heat better than the glass.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Helmholtz View PostIt was my intention to mention nevetslab in a way that would make the system send him a notification mail.
Not sure if this works.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
Post with pictures and solution here: https://music-electronics-forum.com/...358#post794358Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
I've also experienced both ringing/microphonics and cracked glass from the spring type retainers, and avoid them wherever possible. When unavoidable (KT88's, 6550's, etc), I do similar to nevetslab, with silicone tube on the springs. Rather than split some tubing for the top of the retainer though, I use these. The photo on their website is terrible, they're actually thin flat rings that just add a small amount of padding between the top of the retainer and the glass envelope. First time I bought them I was expecting something more like retainer rings...
Wish there was another source for these clamp type retainers, Fliptops wants a few hundred dollars to ship a dozen pieces to Australia, only other source I'm aware of is Mesa Boogie and they won't ship at all. Can find them NOS on occasion, but would be great to find a reliable/affordable source. If anyone happens to know of one, please let me know!
https://britishaudio.com/products/am...ies-amplifiers
- Likes 1
Originally posted by g1 View PostThese look to be around half price of the fliptops ones:
They also only want about half the shipping that Fliptops do too, but they still want an arm-and-a-leg, works out to roughly $18US per clamp if I were to buy 6 at a time, ouch!
I had a friend who had a homebrew amp and he had some sockets that seemed to be prone to shorting out, and he had retainers with very short springs. The amp would be fine unless you put the retainer clip on and then it would blow a fuse. Neither the crappy sockets or the short springs was "right" so I can't blame the clips, but it is one issue I've seen. Then again this type of retainer can be used with coin-base tubes, which bear trap types shouldn't be used on.
Originally posted by Greg Robinson View PostThey also only want about half the shipping that Fliptops do too, but they still want an arm-and-a-leg, works out to roughly $18US per clamp if I were to buy 6 at a time, ouch!
