Hello. I wonder why not to use a blocking diode between reservoir, meant plate supply and screen grids supply cap. Playing with power supply dynamics versus bass transients should be easier I think if I isolate the screen caps to not discharge in reverse to the plate. Then a series diode should be the easy think to do. But is not very clear the whole picture to me, should.d I have any concern doing that please ? Thanks.
Power supply question
Originally posted by Helmholtz View PostCan you really see the plate supply voltage drop below the screen supply voltage at times?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View Post
Oh yes I can see as the plate voltage goes lower the rising screen currents may damage the screens ..
I think it's good practice to have the screen supply follow and track the plate supply.
So the screen node cap shouldn't be too large.
Also for a high power (bass?) amp the reservoir cap looks rather small.
Originally posted by Helmholtz View Postthe screen node cap shouldn't be too large.
You can still run the preamp supply off the plate node and have the screen node separate.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
...then what problems could be, running the power tubes like in sketch circuit please ? There is any risk to destroy the screen grids please ? DC choke value is 100 ohm around. Plate voltage ca 450V dc. My intention is to keep the screen voltage more "stable" not necessary regulated but out of severe variation of plate voltage under power transients. The current of screens is low, making supply cap bigger think helping to make little stiff. But with condition to not depend by discharge over the plates....this was the ideea...to block it in reverse. I don't know if it work as I don't see the whole pictures. The caps could be 100 uF for the plates and 500 to the screens I just asked if it works or not and why please ? Thanks.Last edited by catalin gramada; 04-21-2023, 07:02 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I don't understand your motives and you didn't respond to my points.
Edit: missed post above.
Generally a stiffer screen supply tends to increase average screen dissipation but there are also other factors to consider.Last edited by Helmholtz; 04-22-2023, 01:29 PM.- Own Opinions Only -
- Likes 1
The attached pic shows B+ (red) and screen (green) nodes of a 50w guitar amp power supply from idle to full load. Screen Voltage hovers near the bottom of the saw-tooth mostly due to losses in the DC resistance of the choke. With lower resistance it would be closer to the center of the saw-tooth. You can see the currents used for idle and full load next to the current loads I1 and I2.
The choke being in series with the diode in Catalin's example will act strangely. At times the left side of the choke will dip negatively (relative to the right side) keeping the diode turned on.Last edited by loudthud; 04-22-2023, 04:31 AM.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
- Likes 3
Originally posted by loudthud View PostThe attached pic shows....
Made me aware of the stepped load feature I hadn't noticed before.
I did a simulation using C1= 50µF, C2= 100µF and L1= 5H/100R.
The current step makes the screen voltage drop evenly without any "undershoot", even though the plate node (mean) voltage gets lower than the screen supply voltage and there is some reverse current through the choke.
I would post the results here if I knew how.
I think inserting a diode would somewhat delay the screen supply voltage drop after the load step.
I also expect increased screen supply ripple with the diode.
Ok, trying to post my PSUD2 results: psud2.pdf
Does this work? (Try the link in the frame below).
The green line is the inductor current (scale on the right side).
Lowering C2 to 50µ causes a temporary undershoot of the screen supply after the load step (idle to full power).Attached FilesLast edited by Helmholtz; 04-23-2023, 09:27 PM.- Own Opinions Only -
