In order to increase the gain of my input stage, I'm experimenting with using a jfet input to drive the cathode of V1 in a cascode. I was initially going to set the grid of the upper triode using a voltage divider from the B+, but I had an idea!
I can ground the grid at 0V, and use the zener I've already installed to drop the B+ as my negative supply using "back biasing". This is the set up. Lemme know what you think.
edit: do I need to capacitively couple the input?
