best resources for learning about audio tube amplifiers
  • best resources for learning about audio tube amplifiers
    I have a weak background, some physics and math, not a whole lot of electrical engineering. Wanted to learn more about audio tube amps, with the intent of understanding more about these classic old circuits, Fender, Marshall, Vox, Ampeg.
    Started here:
    Technical books online (tubebooks.org)
    but the first book I downloaded was an old MIT EE book, that begins with the trajectory of a charged particle in an electric field. I learned lots of calculus and differential equations (they tell me) but this seems to be a bit far from learning about how tube audio amps work.
    The other end of the spectrum was a few beginning electricity books, they most all have V=IR, and describe what a capacitor, resistor, inductor is, etc. Too descriptive to make good use, and too rudimentary.
    What's a few good sources for vacuum tube amps, but a little more technical than the beginning electricity books, but not quite as far as the trajectory of a charged particle in an electric field?
    check your pm's
    nosaj
      Originally posted by mikepukmel View Post
      ...What's a few good sources for vacuum tube amps...
      Check out the MEF threads listed under the following search results. I don't necessarily recommend all the books listed but you can ask further questions about any of the books discussed.
      https://www.google.com/search?as_q=G...ype=&tbs=#ip=1
      Cheers,
      Tom
      PS: The complete URL is "https://www.google.com/search?as_q=Good+tube+amp+books&as_epq=&as_oq=&as_eq=&as _nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=https%3A% 2F%2Fmusic-electronics-forum.com&as_occt=any&safe=images&as_filetype=&tbs=" if you need it.
        The one book that was most beneficial to me, at least for repairing, was the Jack Darr book 'Electric Guitar Amplifier Handbook'.
          That was the first book I purchased. I bought it new in 1965 at my local, at the time, Lafayette electronics store. $3.25 in 1965 dollars which is a bit over $30 in 2023 dollars. The book is available for download but the downloads that I have seen did not include Section III which contains the schematic listings. There was a second edition released that contains additional information and a more extensive schematic section.
          holiganbet betturkey
