Suppose we have an amp with a gain control after the first stage, enabling adjustment of distortion in the second stage from clean and on up. The goal is to make this distortion more useful. I hesitate to use the much overused term "touch sensitive", but it actually is not such a bad description.
I will begin by showing the circuit and describing its differences from the usual one, although you might immediately notice that it draws functionality from some overdrive pedals, most famously the tube screamer. (This tube circuit here seems kind of natural, and I assume that it must have been done before many times; maybe someone has a reference to something very similar.)
The first change from the usual circuit is a tiny coupling capacitor from the first plate to the 500K gain control. This begins cutting gain from about 700 Hz on down. After the second stage, the response below 700 Hz is restored. In between there is distortion. When the gain is adjusted low for linear response, the frequency response of the amp is essentially the same as it would be "unmodified". When the gain is increased, the distortion is very different from the unmodified circuit.
It is useful to look at how a Tube Screamer works. The frequency dependent distortion level is obtained with a single op amp with diodes the feedback path and a series RC in the input path (negative input). This is a very precise circuit operating over a wide range of gains. The tube circuit is similar in effect, but realized in a very different way. There is some variation in the cutting time constant as the gain is changed; this might be thought of as a feature rather than a bug. What does this frequency dependent distortion level (bass cut) do in both the TS, or other similar overdrive pedal, and this tube circuit? When a single string is played, the slower changing parts of the waveform are distorted less than the faster parts, and the higher frequency strings are distorted more and differently from the lower. This means that how you excite the string vibration can have a significant effect on the transient response and the harmonic content of the signal. When multiple strings are played, the intermodulation distortion is very different. The effects of the fundamental and lower harmonics of one string affect another string less than they would otherwise.
In the tube screamer, the filter after the distortion produces mid range emphasis. It is, after all, an overdrive pedal. This tube circuit has a different function, a kind of replacement for turning the amp up and getting output stage distortion, and so the original response is restored.
Why diode distortion in the tube circuit? There are other possibilities. For example, you could just let the tube distort. Or you could use the grid cathode conduction as a diode in one direction, and add silicon in the other. I tried these circuits, and the diode circuit in the schematic is best for me, by a lot. I use two diodes in series to get enough clipped voltage to move the second tube operating point over most of the possible range. This higher level adds more tube harmonics, but without additional clipping.
This circuit by itself does not give huge distortion and sustain. But when that is wanted, a tube screamer in front works very well.
