I have a Music Man "Sixtyfive RD 112" one-channel type of amp probably from early 80's. There is a low gain and high gain input and then there are two jacks titled "input/output" with different voltages in the front panel.
Can this input/outputs used as an effect loop for post-preamp-effects (delay, chorus) and, in that case, how they should be switched? Does the power lo/high-switcher something to do with this?
Please no comments of the possible results of this experiment. I only want to know the technical basis in this solution. And if possible with very simple terms, like "put this switch to that position and plug in the effect output here".
I would appreciate any info on this issue.
