Davis Guitar Amp
  • Davis Guitar Amp
    Hello everyone!
    I'm new to this forum, but you all looked like a pretty knowledgeable bunch. I have a hand-wired Davis tube head, probably from the mid-60s. It has 3 6BQ5 power tubes, 3 6EU7 preamp tubes, and 3 different inputs, but it is not very loud. As far as I know, the caps and tubes are original (RCA).
    Anyway, I'm no expert but I believe the amp needs a recap-- the amp seems not loud given the power tubes available, and distortion/breakup occurs without much cranking up of the volume control.
    The problem is the two electrolytic caps, both Mallorys, don't seem to have a modern counterpart. The one inside the chassis (cardboard casing, axial) says:
    + Mallory +
    Made in USA
    40 MFD 450 VDC
    20-45639
    235-7114A
    and the one sticking out of the top of the chassis (aluminum casing, 3 leads, axial) says:
    Mallory
    Type FP
    Made in USA
    MFD VDC
    40 450
    30 450
    20 450
    20-23964
    235-7112Y 85C
    87 812 C1 (stamped)
    I called Mouser, and they say there is no exact exact replacement for these caps. What do you guys think? What caps would make good replacements, or am I stuck with what I have?
    Thanks,
    Joel @ GoMusicSTL
    These should work:
    CE - USA 40µFx40µFx20µFx20µF / 525V
    Sprague Atom 40µF / 500V
    or if you have room in the chassis you could use some of the smaller and cheaper individual caps.
    David
      And also look over at Antique Electronic Supply for selections of such caps.
        And.... keep in mind that electrolytic caps have large tolerances, ( up to 20% ) so it's not unusual for a 40 uF to read up to 45-48 uF.
        In the "old times" filter caps could be found in multiples of 8 uf : 8,16,32,40, 64, nowadays the closest "standard" replacements for a 40uF are 33 and 47 uf.
        Filter caps values are not all that critical, so I'd say 47 uF would be OK, going over that is not recommended with tube rectifiers because of the high current demand imposed by the large capacitance when switching on. If your amp's PS has silicon rectifiers you could even double the filter caps value without problems.
        HTH
        Best regards
        Bob
