Do you guys know if there is a guitar amp that uses 6AQ5 miniature 7 pin output beam tetrode tubes?
Amp that uses 6AQ5 tubes?
6AQ5
This is a version of DaGeezer's Little Wing amp that originally used 6BM8 tubes. I drew up this schematic but never got around to building the amp.
I have a layout for it also.
Should use a 270 ohm cathode resistor for the 6AQ5's, I think. (per Gibson schematics)
With respect, TubenitLast edited by Tubenit; 06-08-2009, 12:30 PM.
6AQ5 Blues Amp
Ok, I also found another schematic that I drew up some time ago and have built as an amp. It has a layout with it also.
I think the value on the cathode attenuation resistor may be incorrect? I may need to be 540 ohms for each one individually? (or something close to that?)
With respect, TubenitLast edited by Tubenit; 06-08-2009, 12:31 PM.
Micro Champ
Adam Alpern has one with a single 12A_7 and single 6AQ5. I built one and connected it to a Weber 8" speaker and called it a harp amp. It sounded good to me.Attached Files
Gentlemen , we tried a SE 6AQ5 amp with the 6U8 preamp , http://www.wattkins.com/node/15993 ... The amp sounded good , but had a somewhat "ratty quality" to the tone...tried many changes , no luck ... even went with higher V PT ... same thing ??? ... You guys have any idea what could be causing that ???
Here's a thread discussing a 6aq5-based tweed deluxe type clone that I built a while back. . . .
http://music-electronics-forum.com/t12663/
just stumbled on this thread and thought I'd add my 2 cents:
The Excelsior Model 10 used a pair of 6bq5's. I think the tube lineup was 6AU6, 2-12AX7's, 2-6BQ5's, and a 5Y3. The amp had 3 inputs, 1 channel, volume,tone, tremolo with speed and intensity. Good little amp.
Originally posted by davohilts View Postjust stumbled on this thread and thought I'd add my 2 cents:
Should be a simple mod to use the 7 pin socket though.... similar enough.
