Greetings! I have an old Supro S6450 "Royal Reverb" tube amp that I'm trying to repair and cannot find a schematic anywhere. I think it was made in the mid 1960's, but I cannot be sure. It has two channels, reverb and tremolo, (3) 12ax7's, (3)6973's, (1)6eu7 and (1)5R4 tube. Channel 1 works, but channel 2, the reverb and tremolo does not...apparently. I think the reverb and tremolo are associated with channel 2 on this amp and therein lies the problem with that. I have swapped out all of the tubes and that does not solve the problem. The power section obviously works since I get sound out of Ch1. I have replaced several tube sockets which did not hold those tubes in place very well and several old cardboard capacitors in the channel 2 circuitry and this got rid of some static noise, but did not solve the problem. The input jacks and potentiometers all test ok as does the reverb tank (used an ohmeter). All of the tube bias voltages are there, and I get a signal out of the CH2 12ax7 preamp tube (checked it with an oscilloscope). I think the signal for CH2 is getting lost somewhere in the input or tone circuitry or possibly in the reverb or tremolo section. I get no reverb or tremolo in CH1, but I'm not sure I'm supposed to. I can hear a very faint sound of my guitar coming through the speakers when plugged into CH2 and some hum when I turn the volume all the way up, but no amplified signal.
The closest schematic I can find is a Gretsch G6162 amp which I understand was a rebranded Valco, but it has a 12ax7 instead of a 6eu7 in the power section and (4) 12ax7s in the preamp/reverb/tremolo section instead of (3) 12ax7's and a 6973. I would appreciate any suggestions or help of any kind, particularly a schematic but I've lost hope of finding one of those. I also suspect this amp is rare since I can find nothing about it anywhere on the Internet, so I'm interested in any history I can find. I'll try and attach some pics.
Best Regards,
Russ Rozell
Best Regards,
Russ Rozell
