Hi, & thank you for your help. What is the pot inside of my Ampeg Gemini II for? I turn it and nothing seems to happen. Thanks, Dan
Ampeg Gemini II: Pot inside chassis?
Originally posted by livelydan View PostHi, & thank you for your help. What is the pot inside of my Ampeg Gemini II for? I turn it and nothing seems to happen. Thanks, Dan
Sometimes a blown power tube will take those hum balance pots right out so yours... (if that is what it is)... could be burned open.
Originally posted by Bruce / Mission Amps View PostThere is a little filament supply hum balance pot in some of those... look to see if it is across the filament supply line.
My Gemini II has a hum-balancing 100 ohm rheostat wired between the power tube cathodes (wiper to gnd.)
Quite a few variations on the Gemini II, though. I've got the 7591's, and the schematic for this version isn't easy to find (on the web, anyway.) The "Joe Piazza" schematics, for instance, don't show the rheostat--neither the 7591 or 6L6 versions.
Is the POT you describe mounted on the back? You can see a couple photos here.
Originally posted by gmoon View PostMy Gemini II has a hum-balancing 100 ohm rheostat wired between the power tube cathodes (wiper to gnd.)
Soldered on the eyelet board?
Some G-15's have a POT to adjust the bias voltage. Look closely at the second photo on the G II thread link above--there's a small trim POT with a blue plastic collar ("knob.")
And yep, that's "right close" to one lead from the indicator lamp.
If that's what your seeing, it's the adjustment for the power tube bias. You won't necessarily hear much difference when fiddling with that POT, but it will definitely effect the operation. Bias it too warm (closer to GND), and you'll shorten the tubes life (redplating, even--which will quickly fry the tubes, and can lead to other problems); too cold (more negative in respect to GND), and it might sound sterile or harsh.
It can be a subtle difference in any case...you're not likely to hear much audible change at lower volume levels...Last edited by gmoon; 02-22-2010, 02:13 PM.
The size of the POT wouldn't matter--if that's indeed what you've got.
I'm not certain yet you've got the same Gemini II setup (7591's, 7199 PI, etc.) Not that 6L6's couldn't have a bias voltage POT, of course. I think a pic would help here.
There's also a schematic for this particular 7591 G-15 on the that other forum page--it's not an easy one to find (mostly the Joe Piazza schematics are posted online); it shows both the bias POT (marked BIAS, just left and below the bottom power tube), and the approx bias voltage, noted as APP. -22V (based on 1965 line voltages .)
I don't suppose you marked the original POT setting before you turned it...?
As far as biasing, there's learning curve. I'll point you to RG's Tube Amp Faq...
Let's try it this way. Pots have three legs, or three solder lugs if you prefer. EAch will be connected to something. I am assuming by wires in this amp, short ones or long ones. To what do each of the end leg wires connect? And the center leg? If the end legs connect to a pair of wires twisted together that runs from tube socket to tube socket, then it is the heater balance pot Bruce mentioned. If the wires run to a pin on each power tube socket, then it is likely a balance pot. Or measure for DC voltage on its legs while the amp is running. If you find a negative voltage there, it is a bias adjust.
If the pot solders right to an eyelet board, there will still be other things sharing the eyelets - wires, transistors, something.Education is what you're left with after you have forgotten what you have learned.
