What year Twin Reverb?
  • What year Twin Reverb?
    I am trying to figure the year of my Twin Reverb out...
    It states... Fender Twin Reverb Fender Musical Instruments
    It has Vibrato a silver cloth front and black sides
    it has a number stamped in the back... 9935
    It is 135 watts
    8 ohm speakers
    on speaker it says 005379
    CBS instruments fullerton
    It is 135 watts
    8 ohm speakers
    Fender Amp Field Guide says that CBS/Fender made the 135-watt Twins between 1977 and 1982. If the faceplate is silver (not blackface-style), then that rules out 1980-1982. Is there a serial number on it that starts with an "A" or "B" (it would have five digits after the letter)?
    Hope that helps!
    - Scott
      It is 135 watts
      8 ohm speakers
      135 watts indicates late 70s. Any other numbers on the speakers? There are numbers on the transformers starting with 606; what are those numbers?
        The 005379 number on the speaker is stamped on just about every Fender labelled 12" 4 ohm speaker I have seen from the mid- to late-1970s. Is there another code stamped somewhere on either speaker? Otherwise there should be codes on the mains transformer. You should be able to read it without pulling the chassis.
