I'm having a hum problem with my old 74 Marshall and I hope someone can lead me in the right direction. Don't ask when the problem started because I don't know. I use my other amps more often because this one is just so friggin loud..
It has no other issues other than the hum. This amp is, guessing, an 8 out of 10 on the inside and a 5 on the outside. The only mod in the circuit is for the AC input, an added AC extension socket and a rotary impedance selector. It used to have a master volume mod but I took it out.
The pic I've posted is before I took out the master volume and re-caped it. The presence is in the rear and mst vol is in the front in this pic. I've also rewired the AC since this pic too because it was pretty crappy. One more thing, the neutral and hot connected to the pwr switch in this pic is incorrect. I've reversed them and I'm 99% sure it's correct now. It seems to be hard to find pictures of the inside of this amp.
If any other pics are needed, please let me know.
Edit: It's plugged in to an AC socket that has it's own dedicated 6 foot ground stake.
Situation:
It has a 60 cycle hum at idle, both volumes turned all the away down and no guitar cord plugged in. It's fairly loud and annoying but sounds fine otherwise. The hum is as loud as normal TV watching.
No change pulling V1
Pulling V2 lessens the hum but it is still there.
pulling V3 lessens it even more but it is still there. Now this is really quiet and if you weren't paying attention you'd say 'what hum?', but it's there if you listen closely.
Putting into standby I still hear the hum and if I pull the power tubes, it is the same. This hum level is the same as pulling V3.
So I'm thinking that this is being amplified when all the tubes are in.
I've tried different tubes in all positions including another set of el34s.
I've tried lead dress adjustments of the wiring.
I've cleaned all the pots.
It has new F&T can caps (10 months ago).
I'm thinking at this point that the power supply is causing this or possibly the heater circuit.![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
![Stick Out Tongue](https://music-electronics-forum.com/core/images/smilies/tongue.png)
Situation:
![](http://i76.photobucket.com/albums/j7/maxwedge572/Music%20Gear/Amps/74%20Marshall%20JMP%2050wt/Chassisw-mastervolume.jpg)
