I have a question about caps and a Bandmaster amp..
And any other parts that could need replacing. I was considering selling this amp that I found at a pawn shop but my local "tech" (an older guy who has repaired many amps over the years but is retired, and was a TV repairman mostly, but he builds tube radios and such..) replaced many of the components of the rectifier, and I replaced the power tubes which were microphonic. Otherwise the amp was performing generally very well, not too loud, but loud enough. But my son was going to use it for a gigging and practice amp, so I need it to work. THat's why I was considering selling it, because I just bought a "more dependable" Musicman HD130 amp with reverb. But I figured I haven't really given this Bandmaster enough attention before selling it.
Here's what it does. After it's been on for a varying amount of time, sometimes when the guitar plays attacked bass notes, a popping sound happens out of the speaker. Then the volume may drop with another distorted popping tone, and it may kick in a bit later. Also, I plugged some synthesizers into it, and played both channels at the same time, and got this really harsh noise coming back at me after a few minutes with the synth plugged in there. It sounded like feeding back of much of the signal or something. Then the fuse blew. I then decided to get the Musicman that was available. But the tone on this bandmaster is really nice. So I'm not ready to give up. But I took some pictures and found out that the caps that are under the shield plate are Mallory caps dated '66 from the codes. This means this amp probably hasn't had any other work than what my tech already did. We noticed it was very clean inside.
Could the caps which are old and need replacing be part or whole of the above-described problem with this amp?
Any and all comments will be read and I'll try to make sense out of it all and then proceed accordingly. I'm thinking at the very least they should be replaced and the originals put in a bag for collector's sake and then I should see just how good this amp can really sound, to let it help me make an educated decision about its reliability and tone.
Thanks.. Sorry for the long-winded intro.. Here's a few pics including an introductory front of the amp, the wiring inside and the mentioned caps...
