I was fortunate enough to inherit my dad's old 60's Sound Projects model R203 tube amp, which he got when he was 12 years old from Montgomery Ward. After searching the Internet for about 5 years now, I have only seen it mentioned less than 10 times. I did stumble upon Lectrolab.wordpress.com however. It has a picture and talks about my exact amp at least. I have attached pictures of all the most important parts of this amp.
I want to make a clone of it so i dont have to beat up my dad's amp carrying it around. My problem is I do not know which transformers to buy in order to make a clone of this amp. It would be nice if there was a simple Hammond equivalent that would not alter the design much, but I don't know what is needed. Since I could not find a schematic for this model anywhere I made my own (attached below w/ all part values and tube pin voltages) to show the point to point layout. Sorry in advance for its unorthodox style as I’ve never made a schematic before and so it was extremely difficult for me to visualize it any way but in a semi-wiring diagram format.
Is there a way to test what the bigger transformer is putting out without being too invasive? I say bigger transformer because it is possible it is not a power trans but just an isolation trans. Also even though i know that the output trans is putting out 4 ohms, is there anything else i should know about it? I assumed its 4 ohms because the original speaker was labeled 4 ohm.
If you notice, the 120V coming from the wall goes straight to the on/off switch with all parts grounding to the chassis and no ground to the wall. I have heard this configuration along with the set of tubes be referred to as widow maker. I have since changed out the old two prong plug to a three prong with ground to the chassis on the transformer bolt in the hopes that it would make the amp safer. It appears that this amp had been modified previously as the 3 electrolytic filter caps are much newer in their construction than the other caps. The one picture I found on the web of the insides of this amp shows a multi-cap where the 3 newer electrolytic are in my amp. There is one value I don’t know and it is the smallest electrolytic, my guess is 25-25 but all that can be read is 25 vdc. I had to change out the speaker as the old one had a rip in it. I replaced it with a Jensen p8r as it was the closest thing i could find to the original.
I appreciate anyones input, thank you in advance.
