Does anyone know the ohms rating for the aux speaker output on a 1966/67 Vox Cambridge Reverb? The manual is no help. Thanks, Barry
67 Vox Cambridge Reverb AUX SPKR OHMS RATING?
Looking at the schematic the "aux" speaker jack is parallel to the "in amp" speaker which is 8 ohms. So ANY load you plug in will affect the amps "ideal" load in a negative way. If the amp ideally wants to see an 8 ohm load (as the schematic suggests) I would say that if you want to use an external cabinet it would be best if it were 8 ohms AND you disconnect the internal speaker. Short of that I would assume that the intention of the jack is similar to that of the old Fender amps as the arrangement is similar. That is, the amp wants an 8 ohm load BUT you can plug another 8 ohm load into the "aux" jack making it a 4 ohm load. This isn't going to give you the most efficiency from the amp but it shouldn't hurt it either. Most amps can operate safely with a +/- 100% mismatch. And I would assume that since your amp has a jack at all that it's up to the task. What else would the designers expect or suggest as a use for that jack. So...
The amp is best with an 8 ohm load. To run an 8 ohm load you must use either the internal speaker OR an 8 ohm cabinet plugged into the aux jack and the internal speaker disconnected. The amp is also fine with with a 4 ohm load though that isn't the most efficient way to operate the amp. A 4 ohm load would be the internal 8 ohm speaker in place and another 8 ohm cabinet plugged into the aux jack, OR the internal speaker disconnected and a 4 ohm cabinet plugged into the aux jack.
FWIW you could safely plug a 16 ohm cabinet into the aux jack with the internal 8 ohm speaker in place. The amp itself won't mind since this would present a 5.33 ohm load (in between 4ohms and 8 ohms) but the internal speaker would recieve most of the power since it has the lower impedance.
Also FWIW you could change the internal speaker to a 16 ohm model and plug another 16 ohm cabinet into the aux jack. Since the aux jack is in "parallel" with the internal speaker this would present the ideal 8 ohm load to the amp and the internal speaker and the extention cabinet would recieve equal power.
I hope this is more helpful than confusing.
Chuck"Take two placebos, works twice as well." Enzo
