aA763 to aB763 change
  • aA763 to aB763 change
    Hi all
    Does anybody know when the blackface circuits changed from the aA763 to the aB763 types.
    Tia!
    Love, peace & loudness,
    Chris
    http://www.CMWamps.com
    If you look at the Fender Amp Field Guide,you will see that different amps show different dates for the associated circuit.Like the BF Bandmaster lists the AB763 from '63 thru '67.But the BF Deluxe shows the AA763 was made from '63 thru '66.The Princeton shows the AA763 went to the AA964 during the same period.So the best I can come up with is somewhere between '63 and '68
      Probably when Fender ran out of the pre-printed tube charts!
      Cheap skates they were.
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        nope & nope (no pun!!!!)
        I just want to know when in '63 or '64 they did introduce the aB763 versions after the aA763 versions.
        Chris
          Fender Amp Filed Guide
          Hi Chris
          I found this here: http://www.ampwares.com/ffg/index.html
          # Circuit Code: In 1963 Fender stoped using model numbers to identify schematics and began using the model name and an assigned circuit number. These circuit numbers which are located on the tube chart can be usefull for getting a rough date on an amp. Fender often used the same circuit for many years so this is not a very accurate method for amp dating. The code is simple, the first two letters are the revision, where AA is the first revision, AB is the second, etc. The next one or two numbers are the month where January is 1 and December is 12. The last two numbers are the year.
          Example: AB763 = second revision, July, 1963
          AA1070 = First revision, October, 1970
          # Misc Dating Info:
          * Silver face amps with the aluminum trimmed grilles are from 67 or 69.
          * The fist Master volume controls were installed in 72.
          * The raised "Fender" grille logo lost its tail around 76. There are exceptions to this rule like the the Bronco.
          * Fender installed casters on some larger amps and cabs beginning in 72
          Stefan
            Originally posted by Chris / CMW amps View Post
            Hi all
            Tia!
            End 63
            Al
              Originally posted by AlAmps View Post
              End 63
              Al
              Danke schön.
              Chris
                Does anybody realy care? If so I can't imagine why. I don't have time enough to try...
                Sorry Chris - this just reminded me of an old Chicago tune... <grin>
